C12X Transmit Messages
Sun Jul 30, 2023 5:20 am
by 01-0041
Hello all,
I thought I had a handle on this, but I'm stuck.
Is there a way in import a DBC file that keeps all of the transmit functions without using DC?
Thank you!
Re: C12X Transmit Messages
Mon Jul 31, 2023 9:48 am
by SOReilly
Currently the import DBC function will only create receive CAN sections.
This has been marked as an item to be reviewed in future.
Regards,
Scott
Sat Aug 05, 2023 7:05 am
by hamer
I'd love to see this feature as well.
Right now I have to import the DBC, screen shot all the settings of each channel under "received channels", change to transmit, then manually re-enter those settings.
It would also be great to have the settings for transmit be a little more clear cut, with starting bit, length, etc, so you can actually see what you're setting up a little more clearly.
