map problem with 2D Table
Postby HMeier on Fri Feb 24, 2023 8:19 pm
i have a problem with the 2D Table mapping.
I want map a CAN Signal/Channel raw data to a new Channel with other values.
The row data is from 0 to 8000 in hex -> 0 to 32768 in decimal.
My problem is that i can only enter decimal values to 32767.
In a CAN Simulation, if i send 8000hex/32768, the Display shows a -135.
Is there a solution how to fix that or a other posibillity how to Map Signals?
Best regards
[img]
[/img]
HMeier
Re: map problem with 2D Table
Postby David Ferguson on Fri Feb 24, 2023 11:40 pm
Change your CAN comms template to be unsigned, or use 32767 (the largest signed positive value you can have in 16 bits).
Postby David Ferguson on Fri Feb 24, 2023 11:48 pm
Another way (incorrect, but easy), would be to add an entry for -32767 (8000 in hex for a signed value) to be 45 as well.
