C127 Reverse Display Button Problem
I have a C127 dash and have setup several pages using DM and DC. Pages cycle correctly with the green button and the red button works for clearing alarms. I am trying to setup a reverse button to avoid having to cycle through each page if I go past the page I wanted. See attached image. I setup a button on AV4. I can cycle backwards in the page lineup 1 page and the button then stops working and I have to turn the power off then on again to get it work again. I set the button channel to display on the screen and it shows a zero until i click the button and then it goes to a 1 but not back to a zero. I thought maybe I need to add the button into the page condition with some logic (already tried adding different logic inside page conditions) but I cannot figure out if that is right or it is a simple logic problem or I am headed down the wrong path? Any help is appreciated.
Charles
Charles
