C187 which dash template in Dash Manager?
Postby HMeier on Fri Feb 10, 2023 9:36 pm
i want to configure a MoTeC C187 with the Dash Manager. When i create a new file, i can choose a template (Default, Demo, M1, M4 M48, M400 600 800, M84 and OBD-II). Which template should i take? The default template has for example no Channel "Logging Running". Other templates has. Only 7 Channels for 5V/8V Aux Supply, Bat Volt Dash, Dash Temp, G Force Values. Which template can i take for the C187?
Best regards
HMeier
Re: C187 which dash template in Dash Manager?
Postby Stephen Dean on Mon Feb 13, 2023 8:47 am
What other devices are in the vehicle? If you have a MoTeC ECU then use the matching start template for it. If you only have the C187, or a non-MoTeC ECU in the vehicle, then I would start with the Default option as this is a mostly empty template and lets you build the configuration to suit your requirements without needed to remove a lot of pre-configured settings, such as are present in the ECU based templates.
