This might not be the correct sub forum, but I think my problem is pretty isolated to the C125 display/ dash manager software.
I'm working on an M150 paired with an external transmission controller and an 8 speed gearbox. I have a developer license, and have messed around with it in M1 Build a little, but am no expert. I've modified the firmware slightly to read 8 gears instead of the standard 7. I've tested this and all 8 gears are properly registered in M1 tune.
My problem comes with integrating my C125 with display creator. My display only shows up to 7th gear, despite the gear channel showing 8th gear in M1 tune. I think I've got display creator set up properly as it works as desired in simulation when gear is set to 8.
I think the problem is in dash manager. When I live track the gear channel in dash manager, I only see it register as 7th gear even though M1 tune is showing 8th gear. I get the gear channel to the C125 with the M1_General_0x640_Version 5 CAN package.
Does this general CAN package limit the gear channel to 7? Or does anyone have another idea where my problem might be? I thought if I got 8th gear displaying properly in M1 tune it would work fine, but that's not the case.
