C127 sequential CAN messages?
Can the C127 decode sequential CAN messages?
I have a device connected which sends a block of 9 sequential messages containing various signals.
In the Dash Manager Comms setup, I added a CAN 'Receive Message' with the starting Base Address, and added all the Received Channels I am expecting, using the 'Single' Message Type option.
In each Channel, I was able to set Offsets greater than 0-7, so set these to the correct byte offset in the whole sequential data, i.e. offset 9 would be the second byte in the second message in the sequence.
The C127 only appears to see the signals from the first message (the base address).
So, does the option 'Single' option mean just a single 8-byte message is received & decoded?
Could I use the 'Compound' option, or does this expect an index in the messages?
Should I just create separate entries for each message address in the sequence, and add the relevant channels to each?
