Help with Changing Throttle position sensor input data C127
Hey all,
I bought a Porsche Boxster race car 2 years ago w/ a C127 and a V2 Camera in it. I have slowly learned Motec programming as I have needed to make adjustments and changes but have a long way to go. Anyhow to my question.
The C127 I have receives input from the stock Bosch throttle position sensor, I assume via CAN.
The V2 camera I have shows 94% throttle when the throttle is in fact fully open (have verified it does fully open).
I need help with figuring out how I can read the real time throttle input (appears to be voltage) then recalibrate the C127 as to what voltage represents 100% throttle.
Can I read the Throttle position voltage somehow real-time under Monitor Channels with my laptop connected to see what it shows at WOT?
Then I am thinking I can input this into the Throttle position sensor voltage under Devices > Throttle position sensor to adjust it? Below is what it currently shows for calibration. It looks like currently there are 2 values for 0% and two values for 100% throttle, not sure why that would be.
Can someone point me in the right direction? I wanted to ask here before I start changing things and end up unable to go back to the original LOL.
Thanks in advance.
Thanks in advance.
