Display change from keypad buttons
Postby NAVSENG on Tue Apr 26, 2022 7:52 am
I am having trouble making a page up and page down function work from my keypad to the c125. I think part of my issue may be the way I have the button configured. Since there is no output channel like switching on a fan or something like that, I don't see the options on what the button function should be (in PDM manager). What do I do here?
Also not sure how to configure it on the C125 side. I have a config that uses a standard harness with a single button for mode change, is this where I would tell it to use the Keypad button? I didnt see anywhere to differentiate between up / down. I suppose I could to it all with one button if that makes it work
NAVSENG
Re: Display change from keypad buttons
Postby Stephen Dean on Tue Apr 26, 2022 10:14 am
Can you attach your PDM and Dash configuration thanks, there are a number of different ways that this can be done but seeing what is currently configured is needed to point you in the correct direction.
Postby NAVSENG on Tue Apr 26, 2022 6:00 pm
Attatched , still learning so I dont have it all together yet.
c125.c125v61
(859.71 KiB) Downloaded 790 times
pdm.pdm
(62.7 KiB) Downloaded 668 times
NAVSENG
Postby RRB on Tue Apr 26, 2022 10:44 pm
I struggle with some of the same problem so nice if you share the solution here
Best regard Ronny
my car has
M400
PDM15
Keypad15
C125
RRB
Postby Stephen Dean on Wed Apr 27, 2022 10:46 am
I have created a CAN Transmit out of the PDM into the Dash, this is sending a Page Up and a Next Line message in to the Dash, in the Dash under CAN 1 (presuming that this is where the PDM is wired to) I have added a CAN Receive template for these two channels. I have then used these channels in the Display setup to change the Page Displayed and to scroll through the lines at the bottom of the screen.
I used the latest public release software to edit the files.
pdm modified.pdm
(60.86 KiB) Downloaded 631 times
c125 Modified.c125v64
(1.34 MiB) Downloaded 719 times
Postby NAVSENG on Fri Apr 29, 2022 3:17 pm
SDean wrote:Hi,
It works but after 30 seconds it goes on continuous loop and changes the page really quickly! Any idea?
NAVSENG
Postby Stephen Dean on Mon May 02, 2022 11:19 am
Try this, I added a CAN Address conflict in the previous version.
(1.34 MiB) Downloaded 895 times
pdm.pdm
(62.95 KiB) Downloaded 733 times
