David Ferguson wrote:The Base Units of the Lap Time channel are 0.01 seconds. if your other device is sending 1078 this would display correctly. If your other device was sending 107800, then you would need a divisor of 100.
Basically take whatever you are currently using and either (multiply the divisor by 100) or (Divide the multiplier by 100).
David Ferguson wrote:Assuming 9001 is decimal, then that is 90.001 seconds, or 1:30.01 displayed as m:s.x. I would use multiplier = 1, and divisor = 1, adder = 0.
David Ferguson wrote:I'm sorry but apparently I do not understand your question.
If you have a value of 90.01 seconds (which came over the CAN bus as a 16-bit value of 9001), you select a display format of "M:SS.HH" in display setup for a Lap Time channel, to have 1:30.01 displayed.
Users browsing this forum: No registered users and 25 guests
