C125 Case Temperature
Postby t8fanning on Sat Feb 19, 2022 9:51 am
I had my C125 hooked up to a 12v power supply while I was working with display creator for probably an hour or so. The only pins with a connection were 12v, ground, and ethernet. After I finished, the device was warm to the touch. Do these displays get warm under use?
t8fanning
Re: C125 Case Temperature
Postby Stephen Dean on Mon Feb 21, 2022 9:28 am
Yes, they will get warm under use, and they will warm up quickly.
Postby t8fanning on Mon Feb 21, 2022 1:30 pm
Good to know. Thank you.
t8fanning
