Kline to CAN
Kline to CAN
Postby Merrell31 on Mon Dec 13, 2021 1:10 pm
I am trying to figure out if a C127 display will work on a gen 2 hayabusa. I know Ryan Schnitz Racing used to sell a C125 with the loom and a “kline to CAN converter” and it somehow plugged directly into the OEM dash plug. I have not been able to figure out how to convert Suzuki Kline to CAN compatible with a C127. Can anyone offer any advice? Thanks
Merrell31
Re: Kline to CAN
Postby Sean on Mon Dec 13, 2021 5:39 pm
MoTeC KTC is the k line to can converter
Sean
Re: Kline to CAN
Postby Merrell31 on Tue Dec 14, 2021 11:33 am
That is what I thought as well. I contacted Motec technical support and they said the KTC will not work.
Merrell31
Re: Kline to CAN
Postby David Ferguson on Tue Dec 14, 2021 12:38 pm
I think the RaceGrade OTC can be configured as a Hayabusa K-Line stream to CAN Stream for the C125. It only receives Engine Temp, Gear and Mode Status. Check with MoTeC USA through the Milspecwiring.com website.
https://www.milspecwiring.com/crm.asp?action=contactus
The OTC (listed in it's GPS config, but it can be reprogrammed):
https://www.milspecwiring.com/RaceGrade ... _2982.html
