Displaying M800 IGN Channel Status
Sun Oct 24, 2021 9:44 am
by HKS_TRD
I have two of the IGN channels in the M800 configured as AUX outputs to control solenoids, is there any way to send the status of these AUX channels to the C127, I couldn't find them in the list of available channels to receive
Re: Displaying M800 IGN Channel Status
Mon Oct 25, 2021 9:55 am
by Stephen Dean
If you add those channels to a Custom Template in the M800 and then transmit that custom template to the Dash (you need to make some address changes if you also use the standard M800 Template) you can receive those channels into the Dash.
Mon Oct 25, 2021 11:40 pm
by HKS_TRD
I must be doing something wrong as those channels aren't available for inclusion in a custom template
Tue Oct 26, 2021 11:41 am
by Sean
If you were using, say, ignition output 5, would the M800 channel Ign Out5 Duty Cycle not show you what you need?
Tue Oct 26, 2021 11:45 am
by HKS_TRD
Yes it would
I'll watch the custom data sets webinar and try again, when I went into the custom data sets setup in the M800 the ignition outputs weren't in the list of available channels
Tue Oct 26, 2021 12:18 pm
by Sean
When you go to add channels in to custom data sets, have you ticked the "show non sensor channels" at the bottom of the dropdown menu box?
Tue Oct 26, 2021 12:20 pm
by HKS_TRD
Not from memory, I'll check that tonight
Also, when I export the template where is it exported to I couldn't actually find it on my PC
Tue Oct 26, 2021 12:33 pm
by Sean
Should be something like this >
C:\Users\username\Documents\MoTeC\Dash\Comms Setup
Tue Oct 26, 2021 12:34 pm
by HKS_TRD
I'll give that a go tonight
Tue Oct 26, 2021 12:36 pm
by Sean
Or the other place to look would be>
C:\Program Files (x86)\MoTeC\Dash\Comms Setup
