Creating custom or new CAN template for C127
Postby rayhall on Wed Aug 04, 2021 4:15 pm
Hello ,
I am going to buy a C127 display. I have been told that I can create new CAN templates for the other devices I made that are on the bus. I only have one CAN bus every thing is connected to this bus and runs a 500kbits . There is a M150 ECU two ECU Master PDM and two small ECU I made. I have tried to create a template, but I find I cannot add the item names and have to select from an existing list in the CAN template creation software. Here is a screen shot of what I want to add as a new template. Another question can I add these to the M1 template to make it easy,
rayhall
Re: Creating custom or new CAN template for C127
Postby David Ferguson on Thu Aug 05, 2021 3:51 am
You can edit the channel names in the C127 Dash Manager to suit your needs. Use Tools->Edit Channels... (be sure to tick the "show unassigned channels" to see the whole list) to accomplish this. Usually we use the GP <Units> N channels that have the appropriate units and resolution, then edit the name to mean something to us for configuration and analysis.
Postby David Ferguson on Thu Aug 05, 2021 3:58 am
For the channels you've shown (jsut realized I didn't scroll to see them all, but you get the point), I would probably use the existing channels:
Fuel Level
Ambient Temp
Cruise Ctrl Status
Air Temp Icooler In (or Icooler Water T In XX if this is really water temp)
Air Temp Icooler Out
Lights High Beam Status
Indicator Right
Indicator Left
You will have to create channels for your Horn status
Postby David Ferguson on Thu Aug 05, 2021 4:00 am
The other way you can do this is if you have a DBC file describing your messages / channels, then using Import DBC will create all the channels for you with the exact names, I believe.
Postby rayhall on Thu Aug 05, 2021 10:39 am
Is there standalone software to create BDC files or template files. The display creator software looks like it could allow me to edit a BDC file if edit was enabled.
Ray.
rayhall
Postby adrian on Thu Aug 05, 2021 10:54 am
The Vector DB++ software is what we typically use to make dbc files, you can download it from their website here
Postby rayhall on Fri Aug 06, 2021 9:13 am
Thank you Adrian,
That Vector software is exactly what I wanted.
Ray.
rayhall
