Use LED lights as throttle percentage
Postby georgemcf on Fri Mar 26, 2021 8:07 am
Hey guys,
I want to use the LED lights on the display to show throttle percentage for standing starts. So our young fellow can use a visual gauge that he has the correct rpm instead of going of engine noise/looking at the display.
Would the correct way to do it be setting up a few user conditions to turn lights on as the RPM increases, and compare this to say ground speed so it only activates when the car is stationary?
Cheers
georgemcf
Re: Use LED lights as throttle percentage
Postby adrian on Fri Mar 26, 2021 8:10 am
Yep, a few User Conditions with "Engine Speed" and "Ground Speed" will be the way to go.
