RS232 Transmit C125 / C127
Hello, I am hoping to configure the RS232-1 TX to transmit some ancillary data back to an ECU that is sending data via the RS232-1 RX to the dash. However I can't detect any data being transmitted from the dash.
In Communications, RS232-1 is configured for the ECU (+ Telemetry) data being send to the dash data and the ECU data to the dash works correctly. I have terminal capture software and it can see the ECU data being sent but not data from the dash. In Functions - Telemetry I selected Motec Telemetry (the original version) and some channels to be output and from my understanding this should have been sufficient to at least get something on the output with the same Baud, etc settings as the ECU uses. I also tried configuring CAN-2 for RS232 RX and set RS232-1 for Telemetry only but still couldn't see any data.
Based on these threads; viewtopic.php?f=14&t=1517 and viewtopic.php?f=14&p=21145 I am hoping that the C12x dashes operate in a similar fashion. Any advice / suggestions would be welcome. Thanks in advance.
