8v output question
8v output question
Postby Doorev1200 on Sat Nov 28, 2020 7:51 pm
Can the 8v output be recalibrated in the channel graph to output 5v instead of 8v? I installed another sensor that needs 5v but i have the 8v slot empty and it would be easier to pop in a term instead of splice into the 5v...
Doorev1200
Re: 8v output question
Postby David Ferguson on Sun Nov 29, 2020 5:14 am
No you can't change the output voltage -- it's a regulated 8V, but you could use a voltage divider to reduce the voltage -- but that's more difficult than splicing the 5V wiring.
Postby Doorev1200 on Sun Nov 29, 2020 3:24 pm
Thank you!
Doorev1200
