m800 oem Ecu lambda to c125 dash
Sun Sep 13, 2020 11:02 pm
by dermot
Hi guys I have an M800 oem Evo 6 ecu with wideband lambda,I'll be fitting a c125 dash soon.
I was wondering is it possible to send the lambda data from the ecu to the dash over the can network/dash loom or do I need to use the LTC and go directly from the sensor to the dash with the data??
cheers
Re: m800 oem Ecu lambda to c125 dash
Mon Sep 14, 2020 11:19 am
by Doorev1200
I believe you can. In dash manager when you go to communications, then under whichever can bus you are using, go to "select" and there is MoTeCM800 (V3.3+)Set1 in the list. Add it and you will see what channels the m800 sends via can. You will see it has lambda in it. You can also go direct from the LTC module with the LTC #1(CAN ID 460) file as well. (I think, I am fairly green yet!)
Mon Sep 14, 2020 12:39 pm
by Stephen Dean
Lambda 1 and Lambda 2 are standard channels transmitted out of the Mx00 ECU's into the Displays.
Wed Sep 16, 2020 5:46 am
by dermot
Thanks guys, good to know before I buy cables cheers
