Old Dash C127 not Supporting Video Camera
Postby mhdazhar on Thu Jun 25, 2020 7:52 pm
I was trying to Install a Video camera to C127(Seriel No:270)
When i try to push the Display Creator file its showing error that the device does not have the video camera support,
when i use a different dash, its working fine.
Can i get a solution for this?..
mhdazhar
Re: Old Dash C127 not Supporting Video Camera
Postby adrian on Fri Jun 26, 2020 9:41 am
The easiest way to check if your C127 can receive video is if it has the USB connector on the back. The video input hardware was added to the board at the same time we added USB logging support.
If you Dash doesn't have the connector then video won't work. Unfortunately there isn't any way for us to upgrade the units.
Postby mhdazhar on Tue Jun 30, 2020 9:38 pm
Okay let me check., i think its an old model so it may not have a USB Connector.,
Thank you for the Support.
mhdazhar
