Display Local Time on C127
Postby DSBE on Sat Mar 14, 2020 6:59 pm
I have a C127 Dash with Display Creator Enabled and I would like to display local time on it.
I have tried to use the Real Time Clock but it doesn't seem to let me set an offset.
Can someone please explain how I go about doing this ?
DSBE
Re: Display Local Time on C127
Postby adrian on Mon Mar 16, 2020 1:19 pm
Below are some example files on how to set it up. The configuration in the C127 is the same as the below C185 example.
To create the offset you add a "Timezone Control" parameter to the channels and functions page.
Clock Example.c185v61
(863.79 KiB) Downloaded 1367 times
Clock Example.dcproj
(38.59 KiB) Downloaded 1237 times
Postby DSBE on Tue Mar 17, 2020 10:16 am
Sweet that worked fine, if only it adjusted for Daylight Savings as well :)
DSBE
