Display Creator C127
Mon Jan 06, 2020 10:04 pm
by adminuae
Greetings,
I tried to make the next button to change the page but I could not
Kindly help me to make the next button to change the page and reset button to increase and decrease the brightness.
Best Regards,
Re: Display Creator C127
Mon Jan 06, 2020 10:35 pm
by rntechnologies
Hi Adminuae,
We would need more information in order to assist you with this one.
Can you post a copy of your project?
If not, do you have a physical button wired into the dash that you want to use to change the page, or are you using a CAN based keypad or another device?
If you have a button wired in, you need to setup an Up/Down counter, and transmit this from the dash to display creator. Once this is done, you can create conditions on each of your pages to utilise the counter and display the correct page.
e.g. an up/down counter, triggered by the physical button input, that rolls at the limit called DisplayCounter
Then in each page within display creator, you would have a condition similar to DisplayCounter = 1 for page 1, and so on.
there are many ways to achieve what you are after, this is just one of them.
Tue Jan 07, 2020 1:43 am
by adminuae
rntechnologies wrote:Hi Adminuae,
See the project in the attached.
Yes, I have these buttons.
Tue Jan 07, 2020 11:15 pm
by adminuae
Thanks, I have found a way
