Acceleration sensor permanent deactivation possible?
Hi Motec team and members,
is there a way to eliminate the functionality of the C-xxx display internal acceleration sensors permanently?
This question may sound weird, but for example with some motorsport regulations it is forbidden to have any other sensors than the ones which are homologated, rally for example.
So is there a way (from Motec HQ most likely) to get a special firmware or whatever is needed, which deactivates these sensors in a permanent way, and therefore comply with the rules. Of course there would be a need to receive a confirmation document from Motec as well which shows for example display serial xyz has locked out accel-sensors, which can't be re-activated by the end-user.
Cheers,
Mike
Cheers,
Mike
