Logging M400 user inputs on C125
Postby 71dsp on Thu Sep 26, 2019 5:28 am
I have a few user defined inputs (e.g. pre-intercooler air temp and water pressure) for my M400 ECU. I do not see them as options for logging or display in my C125. I’d like to display and log these sensors. I’ve looked through the manuals, but I’m still uncertain how the ECU and/or display need to be configured.
The C125 and M400 communicate via CAN, and all of the pre-preprogrammed sensors are there, but not the ones from the “user” tab in the ECU setup.
Any help would be appreciated.
Thank you!
71dsp
Re: Logging M400 user inputs on C125
Postby David Ferguson on Thu Sep 26, 2019 6:03 am
The normal M800 (v3.3+) Set 1 template has User 1 - 4. You will need to edit the template if you wish to use different channel names.
