C127 Standard Layout Options
PostPosted: Tue Sep 17, 2019 8:18 pm
by HKS_TRD
How many different layouts are there to chose from without using display creator and are there any pictures anywhere. I have only seen 2 and wasn't sure if that was all or there are more and if the color scheme was fixed for each layout
Re: C127 Standard Layout Options
PostPosted: Wed Sep 18, 2019 9:40 am
HI,
There are 10 different standard templates for the C series displays, with 16 pre-configured colour schemes. These colour schemes can be modified to suit your needs as well.
PostPosted: Wed Sep 18, 2019 10:09 am
by HKS_TRD
Do you have any images of the standard templates
PostPosted: Wed Sep 18, 2019 10:51 am
If you download any of the C series Dash Managers, and go to the Display Setup window (I), and click on the Change... button (II), you can see the list of display layouts available.
Display Setup.PNG (35.56 KiB) Viewed 10379 times
PostPosted: Wed Sep 18, 2019 10:52 am
by HKS_TRD
I'll download it tonight and take a look
PostPosted: Wed Sep 18, 2019 10:57 pm
by HKS_TRD
I've downloaded the software and started exploring all the options. One thing I couldn't work out is if it is possible to deacticate the large digit that is usually used for gear position. Ideally I would like to have used that gor road speed but being a single digit that isn't going to be an option
