Own a C125 R dash connect to a M150 GPSR can’t get the dash to talk to the ECU.. trying to get the GPS to work. Is this another thing I need to get logging software for dash?? Thanks
Re: GPS
Posted: Tue Sep 10, 2019 12:56 pm
by MalcolmG
It might help if you post a bit more detail about how you've connected everything and how you're trying to get it to work (and what errors you have had). Generally you shouldn't need anything extra unlocked on the dash or ECU to get this function working.
A common set up is: GPS via RS232 to dash (is the GPS working in the dash?) Dash and ECU communicating over CAN (is this CAN bus functioning correctly? Can you send and receive ECU data using ECU Transmit function)? Using the built-in "GPS_to_M1" templates in dash manager to send GPS on 0x680-0x683
If everything is wired correctly, it should be pretty simple to get it all working once we know the set up.
Re: GPS
Posted: Wed Sep 11, 2019 5:57 am
by Fabman500
Thanks Dash is seeing the GPS data Cam is working correctly I add the build in cam1 The RS232 diagnostic says ok
