GPS Position as 3d Table Axis
Postby EB Turbo on Sun May 26, 2019 5:50 am
I am trying to set up GPS position (latitude, Longitude) as axis in a 3D table. When trying to input the axis value I am getting an error that says the value must be between -0.0032768 and 0.0032768. I'm assuming this is an issue with the channel? Is there a way to use GPS lat/long as an axis input?
EB Turbo
Re: GPS Position as 3d Table Axis
Postby adrian on Sun May 26, 2019 8:40 am
The tables are only 16bit so you won't be able to put GPS Lat/Long channels in the table.
What exactly are you trying to do? The new 'Marker' setup in the latest beta of Dash Manager may be of some use.
