I have gear display on C127 dash configured through voltage levels for the gear position sensor. The sensor outputs discrete values for gear positions, R voltage being the lowest, N next, then 1 through 6.
I entered calibration values for neutral through 6, in the gear detection page, and this works correctly for N and all forward gears.
How do I configure proper detection for reverse gear, that's reflected by the gear indicator display portion of the dash?
With current setup, display shows "N" when the vehicle is in reverse.
Cheers
