Updated M1 to Dash CAN Communications Templates
Postby Stephen Dean on Tue Dec 04, 2018 4:45 pm
Hi All,
To go along with the updated CAN Messaging from the M1 using the new v1.10 GP Firmware, we have created a new Master Channel List and templates. These are for both the monochrome and colour displays.
The new Master Channel List that must be copied over the existing file in C:\Program Files (x86)\MoTeC\Channels for it to work.
EDIT: There was a channel missed in the GPS transmit templates, the updated version has been loaded here.
GPS_to_M1_0x682_Version 2.CC8
(8.34 KiB) Downloaded 1572 times
Dash Templates.zip
Dash Templates for the GP release
(104.67 KiB) Downloaded 1830 times
Re: Updated M1 to Dash CAN Communications Templates
Postby mhdazhar on Sat Dec 08, 2018 10:06 pm
In this one will the GPS Time will work for the 12 Series Dashes?
mhdazhar
Postby adrian on Mon Dec 10, 2018 9:04 am
When you say will the "GPS Time work..." what do you mean? How do you have the GPS connected? Is it wired into the Dash or the ECU?
Postby mhdazhar on Tue Jan 08, 2019 5:24 pm
@adrian
i have my gps device wired to the dash,gps speed is working but the gps time is not.,
mhdazhar
Postby adrian on Wed Jan 09, 2019 9:20 am
Can you send me your configuration? If you load the default GPS Template and Speed is working then GPS Time will also be working.
Are you trying to convert GPS Time to Local Time?
