UTC from GPS time
UTC from GPS time
Postby etienne on Wed Jun 13, 2018 12:53 am
on a c127, would you know how to create a channel from GPS time that could give UTC+1 time ?
etienne
Re: UTC from GPS time
Postby adrian on Wed Jun 13, 2018 9:21 am
At this point in time it isn't possible with a C12x Dash as you require Advanced Maths which is only available on the C18x Dashes to create the equations required.
We are working on making this possible in any Dash if you have Display Creator and may possibly add the functionality to Dash Manager in the future.
Postby etienne on Wed Jun 13, 2018 6:46 pm
Thanks !
I'll wait
etienne
Postby gkwestfrank on Tue Jul 17, 2018 9:06 pm
go get the latest beta , it could be done now.
gkwestfrank
Postby etienne on Thu Nov 08, 2018 9:53 pm
I've juste seen that ! Thanks !
Now, i've got to understand how to set an offset...
etienne
Postby etienne on Thu Nov 08, 2018 11:51 pm
I found it !
etienne
Postby etienne on Mon Dec 31, 2018 9:53 pm
I think i've missed something : the value is changing every 2 or 3 sec, never showing the same hour/min
etienne
Postby adrian on Wed Jan 02, 2019 9:30 am
Can you please let me know how you have it set up? Which value is changing every 2 or 3 seconds?
Postby etienne on Wed Jan 02, 2019 8:00 pm
the time shown changes : 12:38 then 4:54 then 18:10 etc etc...
i've activated the channel in dash manager : source GPS time, RTC time offset (constant setup : 3600 s), output RTC/UTC time
i've ad the channel to exported channels to use it in display creator
in display creator, channel used is RTCUTC time with %X as time format.
i've been processing to an update of my c127
i've been sending my new diplay creator project
the only thing i didn't do is sending my dash manager config. Could that be the reason ?
etienne
Postby adrian on Thu Jan 03, 2019 8:46 am
If you make any updates to the Dash Manager file you have to resend it and if you change anything in the Display setup (in Dash Manager) you have to update your DC file and send that as well.
If you are still having issues send me your DM and DC files. Send them to support@motec.com.au
