Sensor output from c185 to m1
what is the procedure for having the dash send out the reading from sensor to m1 ecu?
i'm tryign to send brake pressure from the dash to m1. let's say i'm using can 1 offset 0 in m1tune. set the sensor calibration to cangauge0d.
I've set can receive to default 0f70x
what would be the communication set up i need to use on the c185 dash manager?
the pressure sensure is set to brake press front on one of the AV input of the dash.
