Sensor output from c185 to m1
Postby pehshimaro on Wed Jun 06, 2018 3:23 am
what is the procedure for having the dash send out the reading from sensor to m1 ecu?
i'm tryign to send brake pressure from the dash to m1. let's say i'm using can 1 offset 0 in m1tune. set the sensor calibration to cangauge0d.
I've set can receive to default 0f70x
what would be the communication set up i need to use on the c185 dash manager?
the pressure sensure is set to brake press front on one of the AV input of the dash.
pehshimaro
Re: Sensor output from c185 to m1
Postby David Ferguson on Wed Jun 06, 2018 5:22 am
You might look at this thread, where I help someone send data from their ADL2 to the M1.
viewtopic.php?f=13&t=3936&p=17881&hilit=transmit+to+m1#p17881
Here is the template I am using with my C185 to send by Brake Pressures to the M1. I am using address 0x500.
M1 Transmit Brake Pressure 0x500.zip
C185 Brake Pressure Transmit Template
(354 Bytes) Downloaded 743 times
