C125 - limited number of 2d tables
I’ve used up all 4 of the available 2 tables. Is there any way to add more? Any upgraded options?
I’ve used one of the available tables to generate a rough “differential fuel pressure” by creating table that use inlet pressure where I add my base fuel pressure to boost. I then have an alarm if my actual rising rate fuel pressure drops below the calculate minimum fuel pressure. If the c125 has a math channel I would just do fuel pressure minus inlet pressure. Is there another way I could do this - such as a math channel that I’m missing. This would allow me to atleast create another 2d table
Thanks in advance.
Thanks in advance.
