C125 dash not working
Wed Oct 25, 2017 7:08 am
by trucker
Hello forum I have a problem with my new color dash and need some help. I have a c125 wired into a single can adapter with a m400 ecu. I followed the instructions for setting it up & sending the configuration to the dash from the dash manager software. The dash doesn’t show any of the channels, respond to rpm, show oil pressure, fuel pressure etc just look pretty. The dash is wired into the can1 low & high according to the pinout sheet. So I plugged in my utc adapter to check my ecu setting before I could get my usb cord connected or anything the dash immediately started working. It showed rpm, oil & fuel pressure etc. I unplugged the empty utc adapter & immediately everything dropped back to zero & the dash went back unresponsive. I’m new at this & trying to figure it out. The dash works with the empty utc adapter plugged into the can adapter without the usb cord connected to anything & everything goes back to zero soon as I unplug the utc adapter from the can. Thanks in advance for reading my post.
Re: C125 dash not working
Wed Oct 25, 2017 7:22 am
by br21
sounds like CAN wiring termination, loom needs resistor?
Wed Oct 25, 2017 7:31 am
To be clear -- the UTC adds a terminating resistor. You need to make sure there is one 100-120 ohm resistor between CAN Hi & CAN Lo at one end of the bus (ideally, there would be one at each end of the bus).
Wed Oct 25, 2017 11:27 am
by trucker
Thank You David & Br21 for the response. I will install a terminating resistor & post the results after I’m finished. I hope that’s all it is. Thanks again.
Wed Oct 25, 2017 11:37 am
by trucker
Can i solder the resister directly to the back of the can adapter?
Wed Oct 25, 2017 11:44 am
Yes-- that is sometimes a convenient place.
Wed Nov 01, 2017 12:04 am
by trucker
Well I put a 100 ohm resistor directly behind the can bus adapter between can low & can high. Dash appears to be working now all of the channels went from showing all zeros to actual data numbers. Thanks Again.
