C125 config to C187
Tue Apr 04, 2017 9:45 am
by original.godzuka
is there a simple way to convert the configuration from a C125 to a C187? i mostly care about mimicking the can recieve messages. Thanks in advance
Re: C125 config to C187
Tue Apr 04, 2017 10:27 am
by adrian
There is no way of just converting a C125 config to a C187 config however you can export and import a lot of the data.
If you open the communications setup, highlight a template and then click edit. There are "Load" and "Save as" buttons. You can use these to save all of your templates from one configuration and then load them into the other.
