C125 Speed Input
PostPosted: Mon Mar 06, 2017 6:03 am
by Robbied
I have a C125 up and running in a 2004 Impreza rally car.
Currently I have the OEM gearbox speed sensor wired into SPD1 of the C125 but I know nothing about this sensor.
Does anyone have any settings to get the speed channel up and running in the dash? Its an OEM 6 speed gearbox sensor that has a 12v supply, so i'm assuming its some kind of hall effect switch.
Many thanks!
Re: C125 Speed Input
PostPosted: Mon Mar 06, 2017 11:13 am
by adrian
I had an ask around the office and someone had a vague recollection it was a 4 tooth disk.
Configure the SPD input as follows (I've used SPD2 but it is the same for any of the speed inputs):
Output Shaft Speed.png (27.81 KiB) Viewed 9613 times
If it turns out that it isn't 4 teeth, either adjust the number until it reads right or check just how many teeth are on the disk.
If you want a drive speed rather than an output shaft speed then select a speed channel instead. When you select a speed channel, the calibration window will also have a rolling circumference parameter. When you enter this you need to take into account the final drive ratio as you are measuring the speed before the diff.
PostPosted: Mon Mar 06, 2017 11:35 pm
by Robbied
Thanks a lot, very useful,
I will have a play around with the settings. I think we'll end up using it as vehicle speed, as the car has 4x wheel speeds.
