C125 Speed Input
C125 Speed Input
Postby Robbied on Mon Mar 06, 2017 6:03 am
I have a C125 up and running in a 2004 Impreza rally car.
Currently I have the OEM gearbox speed sensor wired into SPD1 of the C125 but I know nothing about this sensor.
Does anyone have any settings to get the speed channel up and running in the dash? Its an OEM 6 speed gearbox sensor that has a 12v supply, so i'm assuming its some kind of hall effect switch.
Many thanks!
Robbied
Re: C125 Speed Input
Postby adrian on Mon Mar 06, 2017 11:13 am
I had an ask around the office and someone had a vague recollection it was a 4 tooth disk.
Configure the SPD input as follows (I've used SPD2 but it is the same for any of the speed inputs):
Output Shaft Speed.png (27.81 KiB) Viewed 9614 times
If it turns out that it isn't 4 teeth, either adjust the number until it reads right or check just how many teeth are on the disk.
If you want a drive speed rather than an output shaft speed then select a speed channel instead. When you select a speed channel, the calibration window will also have a rolling circumference parameter. When you enter this you need to take into account the final drive ratio as you are measuring the speed before the diff.
Postby Robbied on Mon Mar 06, 2017 11:35 pm
Thanks a lot, very useful,
I will have a play around with the settings. I think we'll end up using it as vehicle speed, as the car has 4x wheel speeds.
Robbied
