C127 PWM outputs
I am trying to set up some functionality where an analog input would be used on another (Non Motec and without user CAN configurability) device in my car based on a counter in my PDM.
Is it feasible to use a table in my dash (Using the PDM counter output on CAN as an input to the dash) and a PWM output to generate a variable DC voltage for input to the other device? I would imagine I would need to build a small LCR filter circuit to smooth the output from the dash but if it is something that is just never going to work I will have to think of another way. It is actually intended to be an input to control trim on an external boost controller from buttons on a keypad attached to my PDM but I may well find other uses if it is feasible.
