3D table question
In a friends dash I have set up a 3D table which as the manifold pressure from the ECU as one axis, fuel pressure as the other and a calculated differential pressure as the output. The table is set to produce the "Real" fuel pressure for display on the dash and to enable easy alarming for fuel pressure issues.
The question I have is, how many rows and columns are warranted? Currently I have a great number of rows and columns from well into vacuum manifold wise and with 0PSI to 100PSI on the fuel pressure input (To match the 100PSIG sensor used)
Is there actually any point in having 5PSI increments for instance or can I simply have as the X axis, something lower than the lowest absolute manifold pressure expected as one value and a second value above the highest manifold pressure expected and similar for the fuel pressure input on the Y axis and let the dash interpolate between those extremes? Do I get any resolution improvement by adding more intervening values in the table?
