Display Wideband on Dash - need help please
Setup
I have configured an A/V input on my dash as follows:
Lambda with GAS AFR unit conversion ? (not sure how I did that to begin with in all honesty),
Ratiometric with the following values
0v = 7.23 AFR
5V = 22.39 AFR
I am using display creator to layout my information as wanted / needed.
The sensor is a Bosh sensor provided by innovate motorsport in their LC2 kit.
http://www.innovatemotorsports.com/products/lc2.php
Challenge / Issue:
C125 value reads slighting higher that directly from the Wideband Controller and higher than a factory installed wideband sensor (via ODB2)
What can I do to make the readings the same ? or better yet, to keep the C125 from rounding up.
I only want to display one decimal.
0v = 7.23 AFR
5V = 22.39 AFR
Challenge / Issue:
