Lambda reading on C127
Tue May 03, 2016 11:17 pm
by alexmas0n
I just purchased a C127 and was wondering how to wire an LSU 4.9 directly to the dash. I have the I/O upgrade on the dash. Is it possible?
Thank you.
Re: Lambda reading on C127
Wed May 04, 2016 5:04 am
Your LSU 4.9 sensor cannot be wired directly the the dash. It requires a lambda controller (such as the MoTeC Lambda-To-CAN module, the LTC). You would connect an LTC using the CAN bus, plus 12V power wired to your ignition power. You configure the LTC under the communications window.
Wed May 04, 2016 12:05 pm
by FoxSTI
Alex, you can also look at innovate LC1 or LC2 that is what I have as far as contoller and plan on connect it to my C125 once I get the I/O upgrade.
