C127 max sensor supply output current
I have not been able to find this information in the manual or so far in browsing webinars.
I have just bought a C127 and due to a current lack of ECU inputs (The budget does not stretch to a more current ECU this year) I have had the I/O option enabled and plan to directly sample several values directly on the dash, among those being oil pressure and temperature via AV inputs. The pressure inputs will generally require a 5V sensor supply
The 5V Sensor supply in the C127RLC is used for the GPS and I would need to modify the loom to allow access to it for other sensors due to the way it is cabled, however could Motec or anyone else in the know confirm what the maximum output current for the 5V sensor supply is in a C127?
