Configuring Speed Input Pins
Postby PaddyMcP on Thu Mar 17, 2016 3:11 am
When configuring a hall switch or mag sensor without data sheets, is there are way for the dashes to read the raw high and low voltage levels?
I'm familiar with osc scope mode but I can't seem to be able to view the raw voltage levels in order to set the trigger levels for the speed pin configurations.
Is there a clever way to do this?
Thanks in advance…
PaddyMcP
Re: Configuring Speed Input Pins
Postby JamieA on Mon Mar 21, 2016 11:10 am
in C187 you can log the speed voltages on the duplicate pins.
JamieA
Postby PaddyMcP on Tue Mar 22, 2016 3:32 am
Thanks Jamie!
PaddyMcP
