units for fuel pressure C125 - M84
Hi
I'm running an M84 with C125 dash.
Getting strange reading for fuel pressure in psi on dash says pressure only 5-7 on prime up (actual pressure is 45-50psi)
I have the unit in dash set to psi but its like its reading the pressure in psi as a kpa reading then converting (again) to psi
I have tried setting up a new file using M84 template but same result.
Really strange thing is that it used to show correctly and to my knowledge we haven't changed anything ?
Is there a setting in the M84 I need to change ?
thanks
Wade
thanks
Wade
