C125 Aux Output for Tachometer
All,
I’m in the planning stages for my C125 and would like a bit of help.
I’ll be using the C125 in a US spec ’95 E36 M3 (OBD1) that will be eventually be running either an M130 or M150 depending on how I can utilize channels.
Of the two options; which of the following “Duty Cycle Control” or “Frequency Control” would be best for an RPM output - signal for factory tachometer - of no more than 8000 rpm and what’s the best method for setting it up once I load the "M1_General" CAN list?
Thank you for your time!
