Hondata kpro4 to C127 issue
Re: Hondata kpro4 to C127 issue
Postby Firas on Fri Feb 02, 2024 12:39 pm
Hi David,
I have attached the config file im using and the can inspector capture also
just did a quick test and Im sure the data is transmitted in deg C after running the vehicle for a little
and a quick conversion on the data in can inspector shows the temp corresponds to the ecu temp even though ecu is showing it in deg F for coolant temp
for ID 0x661 - 002B - 43deg c - 110deg f
I think my issue will me the multiplier/divisor/adder
Multiplier I assume will be 10 as base is 0.1 degc
I would love to know what these mean so i can understand how to set this up, as there is little online i can find on this subject. Do you have any recommendations or can direct me on how to gain this knowledge
caninspector.asc
(73.67 KiB) Downloaded 913 times
new c127.c127v64
(1.34 MiB) Downloaded 887 times
Firas
Postby Stephen Dean on Fri Feb 02, 2024 1:50 pm
If the channel is coming across as 1degF and your dash channel is 0.1degC
then the multiplier becomes 50, the divisor 9 the offset -177.
It's not perfect, but it is within 1degC.
Postby Firas on Fri Feb 02, 2024 8:02 pm
Ok I worked out the issue
The templates from Hondata are for IDs 660 and 666
Which included the ecu Battery Volts and rpm etc
I created extra templates that covered IDs i needed for the sensors i require and now I have it working
Stephen,
I now understand what u mean in regards to the multiplier divisor and adder. I just got a little confused as I had no figures at all and thought my interpretation was wrong... its simply what they mean and are used to adjust some raw data to the figures u required. I had to do this for TPS which needed a multiplier of 10 to get the correct % value
This would be definitely challenging from sensors I would assume
Just want to thank you both Stephen and David for your input
Firas
Postby David Ferguson on Sat Feb 03, 2024 4:08 am
Glad you figured this out on your own. The document you need to understand CAN template editing is "DTN0019 - Motec Communications and Setup", it was posted at the end of this forum topic:
viewtopic.php?f=70&t=5505&p=25043&hilit=DTN0019&sid=217b82acabdb2d4505be0581ff056352#p25043
