TPMS on C127?
Re: TPMS on C127?
Postby Stephen Dean on Thu Oct 19, 2023 9:47 am
12mm reamer to the rescue?
So the IZZE Racing TPMS Sensors have an advantage in that they do not have a inbuilt valve stem so you can use the stems that suit the rims.
Re: TPMS on C127?
Postby Auto Sport Elect on Thu Oct 19, 2023 11:14 am
Stephen Dean wrote:A 5Hz update rate is better than the 1hz that they mention in the specs. How accurate are the pressures read by the sensors compared to an accurate tyre gauge David?
I have used these briefly.
They were a resolution of 0.7 psi, and was accurate to a known pressure gauge I trust.
These seem to have a better resolution.
https://www.brightwater.co.uk/datasheet ... erview.pdf
Auto Sport Elect
Re: TPMS on C127?
Postby 13cobra on Mon Feb 12, 2024 3:23 am
David Ferguson wrote:Since I don't have it really working, I can't confirm, the protocol claims to send data every 200ms, but perhaps that's one wheel every 200ms, so closer to 1 HZ.
Our project just came to a stop a few minutes ago. The internal sensors don't fit the valve-stem opening in the BBS wheels my customer is using. Wheels are about 8.5mm, and the sensor needs something like 11.5mm.
Ah, great. I get my car back in a week or two, then I'm planning on putting the sensors in. Fingers crossed they fit the wheel.
13cobra
Re: TPMS on C127?
Postby 13cobra on Tue Mar 12, 2024 6:29 am
(Thanks for all of your help by the way, we're nearing the end) haha
As far as this part goes, same with my BBS wheels. We ended up drilling the wheels out and everything worked perfectly.
13cobra
Re: TPMS on C127?
Postby David Ferguson on Wed Aug 06, 2025 3:46 am
Someone mentioned this post to me, and I wanted for follow up with how we mounted the Trailbrake TPMS sensors to the middle of the wheel using a bracket we machined. Here's a pic.
Machined TPMS Mount
Machined TPMS Mount - 1.jpeg (52.33 KiB) Viewed 8624 times
