Bit packaging into Can Bus message
Postby svanni on Fri Apr 10, 2026 8:49 am
Hello, I'm trying to stuff 8, 1-bit status channels into 1 byte of a Can transmit message. Can this be done in the Can Communications Setup windows?
I know I could do it with a math channel and "decode" it on the other side, but I don't have the math channel option on this c185 dash.
Any ideas? Am I missing something?
Thanks for your time!
svanni
Re: Bit packaging into Can Bus message
Postby SOReilly on Fri Apr 10, 2026 9:54 am
Yes this can be done by setting the bit mask to a single bit, then marking the checkbox to shift the data
mask and shift.png (37.61 KiB) Viewed 263 times
You can see in the example above I have set the mask to 80 so this channel will be placed in the left most bit of the first byte.
The next signal would be the same process but with the bit mask set to 40 and so on.
SOReilly
Postby svanni on Sat Apr 11, 2026 8:15 am
Ah...Okay. That makes sense.
Thank you for the info @SOReilly! :)
I'll give it a try next weekend when I'm back in front of the vehicle.
svanni
Postby svanni on Mon Apr 13, 2026 6:42 am
That makes sense. Thanks @SOReilly! :)
I'll give it a shot next weekend when I'm hands on with the vehicle again.
svanni
