Switched 12v trigger SPD2 input
Postby The Outlaw on Fri Feb 28, 2025 9:06 am
Hi all, was wondering if there’s a way to trigger a SPD input with 12v, from what i understand it needs a ground to trigger, but my switch is 12v and permanent ground..will I need to rewire it so it’s switched ground
Cheers Lee..
The Outlaw
Re: Switched 12v trigger SPD2 input
Postby SOReilly on Fri Feb 28, 2025 11:01 am
The SPD Inputs are pulled high to 2.7v via a 2200 ohm pull up but you can set the trigger threshold to 4.68v.
The SPD pins in hall mode have a voltage range of 0-15V.
Once the channel selected for the SPD input pin, click the change cal button and set the polarity to high volts=ative, then click the spd levels button and change the hall voltage to 4.68v
SOReilly
Postby The Outlaw on Fri Feb 28, 2025 6:47 pm
Thanks for the info, will give that a try..
SOReilly wrote:The SPD Inputs are pulled high to 2.7v via a 2200 ohm pull up but you can set the trigger threshold to 4.68v.
The Outlaw
Postby The Outlaw on Mon Mar 03, 2025 4:57 am
Thanks buddy, worked a treat…
The Outlaw
