About adding WHP TPMS to C127
Postby tikiti-ta on Wed Dec 04, 2024 1:32 am
I purchased a product called WHP TPMS to CAN and connected it to my C127.
I installed the dbc data distributed by the manufacturer, but it does not work properly.
I tried changing the settings a little, but the numbers fluctuated a lot or they wouldn't load.
Can someone tell me about the setup based on this data?
WHP_INTERNAL_RACE_TPMS_DBC (1) (1).dbc
(2.07 KiB) Downloaded 27 times
tikiti-ta
Re: About adding WHP TPMS to C127
Postby Anthony on Thu Dec 05, 2024 1:12 am
Is that the default provided DBC or your modded version?
Can you share your dash config?
Anthony
Postby tikiti-ta on Thu Dec 05, 2024 12:08 pm
Anthony wrote:Is that the default provided DBC or your modded version?
Thank you for your reply
The attached data is manufacturer default
FL5-9-Forum.c127v64
(1.35 MiB) Downloaded 35 times
tikiti-ta
Postby tikiti-ta on Mon Jan 20, 2025 5:52 pm
Solved
The cause was that after I sorted the ID using the initial settings of the installed sensor, it was successfully read.
tikiti-ta
