Seeking Assistance with Adding a PID to Dash Manager
Postby Sedrick on Wed Jan 15, 2025 8:01 am
I have a C125 I'm attempting to set it up to display various parameters from my factory ECU and I am struggling to understand Dash Manager. I also purchased Display Creator should it be necessary.
I've included a PID for my vehicle below.
    name: PIDs - Oil Temperature (705C)
    name: PIDs - 705C
    format: UBYTE
    operations:
    coefficient: 40.0
    operation: SUBTRACT
    coefficient: 1.0
    operation: DIVIDE
    unit: CELSIUS
How would I set this up in Dash Manager? I have jumper cable to get CAN messages from the steering angle sensor and I also have the ODBII connector. So I can do either, but from my basic understanding ODBII connector is needed since I'm using PIDs.
Sedrick
Re: Seeking Assistance with Adding a PID to Dash Manager
Postby David Ferguson on Wed Jan 15, 2025 11:25 am
What is the vehicle make/model you are working with?
Is that a non standard OBD2 Service Mode 21 or Mode 22 PID (Paramater ID)? if so, the format is unique to each OEM and I'm not sure it's documented enough to easily figure out the request/response.
Is there any chance this info might be broadcast on some CAN bus -- if you can figure that out, it usually much easier to deal with.
You can learn about OBD2 standard PIDs from this webpage:
https://en.wikipedia.org/wiki/OBD-II_PIDs
Users browsing this forum: Google [Bot] and 7 guests
