About adding WHP TPMS to C127
Postby tikiti-ta on Wed Dec 04, 2024 1:32 am
I purchased a product called WHP TPMS to CAN and connected it to my C127.
I installed the dbc data distributed by the manufacturer, but it does not work properly.
I tried changing the settings a little, but the numbers fluctuated a lot or they wouldn't load.
Can someone tell me about the setup based on this data?
WHP_INTERNAL_RACE_TPMS_DBC (1) (1).dbc
(2.07 KiB) Downloaded 209 times
tikiti-ta
Re: About adding WHP TPMS to C127
Postby Anthony on Thu Dec 05, 2024 1:12 am
Is that the default provided DBC or your modded version?
Can you share your dash config?
Anthony
Postby tikiti-ta on Thu Dec 05, 2024 12:08 pm
Anthony wrote:Is that the default provided DBC or your modded version?
Thank you for your reply
The attached data is manufacturer default
FL5-9-Forum.c127v64
(1.35 MiB) Downloaded 199 times
tikiti-ta
Postby tikiti-ta on Mon Jan 20, 2025 5:52 pm
Solved
The cause was that after I sorted the ID using the initial settings of the installed sensor, it was successfully read.
tikiti-ta
Postby TheJuggernaut on Thu Apr 10, 2025 9:39 am
Hey sorry I can't PM you, just joined, I wanted to clarify what your solution was?
I able to see the data from the TPMS ecu, I get temps and battery volts but the pressures are just 256 multiples. I checked the IDs using the call/response, 2 were wrong, I fixed them but no difference. I tried the tool to activate the sensors, they're activated, but no values. Tried deflating by 20psi and reinflating, with no change. I'm unable to drive the racecar at the moment to verify if maybe they need movement to send a signal, I thought that triggering the sensors with the tool would be enough, the tool reads pressures just fine. WHP people are useless, I sent the China manufacturer a direct email to ask but so far no reply.
TheJuggernaut
Postby Anthony on Thu Apr 10, 2025 9:36 pm
TheJuggernaut wrote:Hey sorry I can't PM you, just joined, I wanted to clarify what your solution was?
Anthony
